DELTA 3 Ultra Plus Portable Power Station | EcoFlow PH | EcoFlow PH
EcoFlow DELTA 3 Ultra Plus Portable Power Station (Members-Only) EcoFlow DELTA 3 Ultra Plus Portable Power Station (Members-Only) EcoFlow DELTA 3 Ultra Plus Portable Power Station (Members-Only) EcoFlow DELTA 3 Ultra Plus Portable Power Station (Members-Only) EcoFlow DELTA 3 Ultra Plus Portable Power Station (Members-Only)
3072 Wh Capacity
3600 W Output
10+ Years of Use
1. Smart Output Priority: Choose which circuits stay powered via the app. Prioritize what matters and extend runtime when it counts most.
2. 3-11kWh Expandable Capacity: Easily scale up, and can achieve longer runtime with an EcoFlow Smart Generator featuring automatic start and stop.
3. 4 Ways to charge, Ready in Just 60 Mins.
4. 3600W Powerful Output: 7200W surge output. With X-Boost™ mode, supports heavy-duty appliances up to 4600W such as clothing steamers, electric dryers, lawnmowers, and electric frying pans.
5. Long-Lasting, Durable, and Reliable: Equipped with automotive-grade full-tab LFP cells, offering 10 years of reliable power, 24/7 protection BMS, Class-B certification, and EV-grade CTC structure that protects against overnight condensation and off-road bumps during transport.
6. 2 Easy Ways to Connect to Your Home: Manual Transfer Switch and Inlet Box.
7. 10ms Auto-Switch: keep critical devices like NAS systems and servers running smoothly.
8. 25dB Whisper-Quiet Operation: Ultra-low noise (≤25dB at 600W).
9. OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. Storm Guard Mode automatically activates backup power before extreme weather hits. Self-Powered Mode and Scheduled Tasks save you money daily.
10. Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
Learn more
Products
Selection Summary
DELTA 3 Ultra Plus + 400W
₱151,490 ₱195,980
₱151,490 ₱195,980 -₱44,490
₱151,490.00
Basic Model vs. Plus Model
DELTA 3 Ultra Plus
DELTA 3 Ultra
3072Wh
3072Wh
3072Wh
3072Wh
11kWh with 2 × DELTA Pro 3 Extra Battery
0
0
120V~60Hz 3600W total (surge 7200W), 20A(x4) Max per port, 30A(x1) Max per port
12V DC Output Port12.6V-30A, 378W TotalAnderson: 30A Max (Shared power with car cigarette lighter)
No
No
Ready in Just 48 Mins (0-80%) with Solar + Generator Dual Charging
Ready in Just 89 mins (0-80%) with wall charging or generator charging.
6 Ways to charge
4 Ways to Charge
6 Ways to charge
4 Ways to Charge
1600W
800W
1600W
800W
3200W Max, 0-80% Charge time: 53min. 0-100% Charge time: 76min (With EcoFlow Smart Generator 4000)
1600W
1600W
33.7±0.6kg
32.7±0.6kg
33.7±0.6kg
32.7±0.6kg
3600W Output—Powerful. Stable.
Built to Handle It All
DELTA 3 Ultra Plus delivers 3600W rated-output (7200W surge) , with X-Boost™ 3.0 technology, it supports devices up to 4600W—effortlessly handling heavy-duty appliances. The inverter samples AC voltage and current every 33μs with high precision with a DSP chip, ensuring a pure sine wave output with beyond grid-level stability—ideal for powering sensitive electronics reliably.
Kitchen
Living Room
Laundry Room
Home Office
Camping/RV
Professional Works
Kitchen
Kitchen
Living Room
Living Room
Laundry Room
Laundry Room
Home Office
Home Office
Camping/RV
Camping/RV
Professional Works
Professional Works
Run Outdoor Gear. Power Your RV. Charge Your Essentials— One Station Powers it All
Whether you're parked at camp or on the road, the two DC ports—Anderson[2] and car cigarette port—keep 12V gear running, from portable car fridges to car vacuums and air pumps. When you need more power, the TT-30 port enables support for your entire RV setup. And for everyday use, the high-power USB-C port fast-charges laptops and phones with ease.
4 Ways to Charge Up — Ready in Just 60 Mins
Remote charging control for added peace of mind.
Wall Charging
Alternator Charging
Solar + Alternator Dual Charging
1800W Input, 0-80% in 89 mins. [4] EcoFlow's exclusive Storm Guard Mode [5] monitors severe weather alerts and automatically triggers AC charging remotely using industry-leading X-Stream fast charging tech—so it can be ready long before a disaster hits.
1600W input, 0–80% in 101 mins. After the storm clears, just 101 mins of sunlight is all it takes to recharge DELTA 3 Ultra Plus. Pair it with EcoFlow 400W Solar Panels (25% high-efficiency) for reliable power during camping trips, van life, or off-grid living. [3] .
1000W Input, 0-80% in 142 mins. With EcoFlow Alternator Charger Plus 1000, [7] get ready in just over 2 hours while on the move—10× faster than conventional solutions. [8]
2600W Input, 0-80% in 60 mins. Dual input from 1600W solar and 1000W alternator charging keeps you powered faster than ever, even on the go.
Wall Charging
Wall Charging
Alternator Charging
Alternator Charging
Smart Output Priority Tech
Pick Your Priority Outputs, Extend What Matters Most. Manage each outlet remotely from your phone. Prioritize essentials like your fridge or medical devices to extend runtime when it counts most.
Easily Scales Up—From Hours to Days
3–11kWh expandable capacity [9]
Compatible with Smart Generators for unlimited runtime
Half-Day Outage
1-Day Outage
2-Day Outage
3-Day Outage
Covers essential power needs during a 4–10 hour outage—keeping food fresh, cooling running, work uninterrupted, lights on, and communication devices charged. [10]
Delivers 1 days of outage protection—ensuring uninterrupted cooking, cooling, remote working, lighting, and connectivity. [10]
Powers home essentials for up to 2 days [10] with 7kWh capacity—keeping your kitchen running, home office working, lights on, and devices connected. [11]
Supports a family of four through 3 days of everyday living [10] with 11kWh capacity—keeping food fresh, cooling running, lights on, and entertainment devices charged. [12]
Half-Day Outage
Half-Day Outage
1-Day Outage
1-Day Outage
2-Day Outage
2-Day Outage
3-Day Outage
3-Day Outage
* Require connecting 1*DELTA 3 Ultra Plus (3072Wh) + 2* DELTA Pro 3 Smart Extra Battery with EcoFlow Smart Extra Battery Expansion Adapter. * This adapter is currently not available in the Philippines. [12]
Monitor your energy usage and solar generation—all with one intuitive dashboard. Set timed charging/discharging missions so that you can charge during off-peak hours and discharge during peak rate periods to save costs.
Cut Costs, Not Comfort
DELTA 3 Ultra Plus intelligently optimizes energy usage to help lower your electricity bills while powering your home sustainably. Set automated tasks to charge during off-peak evening hours and discharge during the day. To use this feature, update the software to V6.15 or above and upgradethe firmware to V7.80.99.52 or above.[13]
Unrivaled Balance for Unmatched Battery Longevity
With 27% fewer cells per kWh, [16]our 16-cell design runs cooler, lasts longer, and delivers greater stability. Each cell is rigorously tested for capacity, voltage, and internal resistance—resulting in a highly uniform pack that protects against overcharging, imbalance, and premature wear.
Built to Last
From battery chemistry to structural design, DELTA 3 Ultra Plus (3072Wh) is engineered for extreme durability, environmental resilience, and whisper-quiet performance—delivering power you can count on for over 10 years. [1]
Battery Protection
CTC Structure
Durable Qualities
Class B Certified
25dB[18]
EcoFlow's advanced BMS uses a high-performance ARM Cortex chipset and intelligent algorithms to monitor your battery in real time. By tracking SOC, SOH, temperature, and more, it ensures peak performance, extended battery life, and worry-free operation.
Built with a cell-to-chassis (CTC) structure, DELTA 3 Ultra Plus (3072Wh) is drop-resistant (0.2m) —protecting against overnight condensation and off-road bumps during transport. You get stable power even in the most demanding conditions. [17].
DELTA 3 Ultra Plus (3072Wh) keeps your power flowing through freezing cold, scorching heat, humid environments (95% humidity tolerance), or coastal air (5% salt spray resistance). [17].
Certified to Class B EMC standards, it won't interfere with TVs, Wi-Fi, or other home electronics.
Powered by X-Quiet™ 3.0, EcoFlow's stepless fan control adjusts airflow smoothly to maintain precise thermal regulation—keeping your home or workspace peacefully quiet, even under heavy loads.
Battery Protection
Battery Protection
CTC Structure
CTC Structure
Durable Qualities
Durable Qualities
Class B Certified
Class B Certified
25dB[18]
25dB[18]
Compatibility
[1] Based on proper product usage, DELTA 3 Ultra Plus is estimated to have a lifespan of approximately 10 years, according to internal simulation test data. This information is for reference only; actual user experience may vary.
[2] DELTA 3 Ultra Plus features an Anderson port, while DELTA 3 Ultra does not.
[3] EcoFlow Solar Panels are sold separately.
[4] All charging speed data comes from EcoFlow labs and is for reference only. The actual data may vary slightly depending on the usage environment, device condition, software version, and other factors.
[5] Feature requires preset activation via the EcoFlow App.
[6] To enable this feature, connect DELTA 3 Ultra Plus to the Smart Generator using the charging cable and enable the preset in the EcoFlow App. Communication is handled via Bluetooth or Wi-Fi.
[7] EcoFlow Alternator Charger Plus 1000 will be launched soon and is sold separately.
[8] Compared with car cigarette port charging.
[9] DELTA 3 Ultra Plus is expandable, while DELTA 3 Ultra is not expandable.
[10] Backup time based on ideal conditions; actual results may vary.
[11] Require connecting 1*DELTA 3 Ultra Plus + 2* DELTA 3 Max Plus Smart Extra Battery with EcoFlow Smart Extra Battery Expansion Adapter. The EcoFlow Extra Battery Expansion Adapter will be released soon.
[12] Require connecting 1*DELTA 3 Ultra Plus + 2* DELTA Pro 3 Smart Extra Battery with EcoFlow Smart Extra Battery Expansion Adapter. * This adapter is currently not available in the Philippines.
[13] To use this feature, update the software to V6.15 or above and upgrade the firmware to V7.80.99.52 or above.
[14] Refers to the internal resistance of EF Full-Tab LFP Cells being 1.5mΩ, which is 25% lower than the 2mΩ internal resistance of the previous EF #C33 Battery Cell.
[15] A 25% reduction in single-cell internal resistance. According to the heat generation formula Q = I²Rt, under the same current, a 25% reduction in resistance leads to a proportional 25% decrease in heat generation.
[16] Compared with the previous usage of EF #C33 Battery Cell.
[17] Unless otherwise noted, all above data comes from EcoFlow labs and is for reference only. The actual data may vary slightly depending on the usage environment, device condition, software version, and other factors.
[18] Noise levels measured at 1m under 25°C ambient: ≤25dB (600W) for charging/discharging.
[19] Manual Transfer Swith is sold separately.
[20] This accessory should be purchased separately.
[21] Unless otherwise noted, all images, videos, and screen display contents about the product itself on this page are for reference only. Actual product effects (including but not limited to appearance, color, and size) and screen display contents (including but not limited to backgrounds, UI, and illustrations) may vary.
32.7±0.6kg
Dimensions (HWD)
625.99mm×327.71mm×394.95mm
Rated Capacity
3072Wh 51.2V 60Ah
Cell Chemistry
LFP(LiFePO4)
EU: 230V~50Hz 3600W total (surge 7200W), 15.6A(x4) Max per port
INT: 230V~50Hz 3600W total (surge 7200W), 13A(x4) Max per port
X-Boost
4600W
USB-A(x1): 5V-3A/9V-2A/12V-1.5A, 18W Max
USB-C(x1): 5/9/12/15V-3A, 20V/28V--5A, 140W Max(HID)
USB-C(x2): 5/9V/12V/15V-3A 20V-2.25A, 45W Max per port, total 45W
12V DC Output Port
Cigarette Lighter Output Port
12.6V, 10A, 126W Max
AC Input (Charge Only)
EU: 220-240V~10A 50/60Hz
INT: 220-240V~10A 50/60Hz
Maximum PV Input Power(W)
1600W
Optimal operating temperature
20°C to 30°C (68°F to 86°F)
Charge Temperature
0°C-45°C(32°F-113°F)
Discharge Temperature
-10 to 45°C(14°F-113°F)
Storage Temperature
5-Year Warranty
Communication Method
Wi-Fi & Bluetooth
EMC
Class B
UPS
<10ms
Get ₱ 500 OFF
