When the power goes out, DELTA 3 Air keeps fans running for hours, so your family stays cool and comfortable — no more hand-fanning in the heat.
Keep Your Family Cool and Comfortable
Enjoy Mealtime Without Disruptions
Outages don’t have to interrupt dinner. DELTA 3 Air powers lights and fans so meals stay bright, breezy, and stress-free.
Bright Paths, Safe Steps
Candles aren’t enough. With EcoFlow portable power, hallway lights stay on during blackouts, keeping your kids safe and your home at ease.
Powers 99% Home-Essential Appliances
DELTA 3 Air delivers reliable power for nearly everything your family needs—from fans and lights to TVs and refrigerators. And with X-Boost mode, it can handle higher-wattage appliances too, so even cooking with a rice cooker is worry-free.
DELTA 3 1000 Air
DELTA 3 2000 Air
Power That Lasts All Day
With its high-capacity design, the DELTA 3 Air series delivers long-lasting backup for your home essentials. From keeping a light on through the night to running fans and refrigerators during extended outages, it gives your family all-day peace of mind without interruption.
Home Essentials
Home Office
Outdoor
Check DELTA 3 Air Series Charging Time
Appliance
DELTA 3 1000 Air
DELTA 3 2000 Air
Units
Wi-Fi Router
43
80
hours
Light
41.5
73
hours
Speaker (DC)
90
170
hours
Portable Fan(DC)
50
110
hours
Camera
58
110
times
Phone
42
80
times
Display
45
85
times
Fan
20
24
hours
Drone
18
34
times
Starlink
16.3
23.2
hours
Laptop
15
27
times
Car Fridge
19.4
34
hours
TV
8
14
hours
Refrigerator(Based on internal testing of an unloaded refrigerator (150W rate)
20
40
hours
PC
8
15
hours
Coffee Maker
1.5
2.8
hours
Rice Cooker
1
1.8
hours
Get Ready in 2 Hours
With EcoFlow’s X-Stream fast AC charging, DELTA 3 Air fully recharges in just 2 hours—ready before the next outage. For flexibility, you can also top up with up to 1000W of solar, or recharge via generator or car when off-grid.
0 Maintenance. 0 Installation.
Say goodbye to upkeep and complicated wiring. With an all-in-one design that combines battery and inverter, DELTA 3 Air works just like a big power bank—unbox, plug in, and power your home essentials instantly.
Compact Design, Fits in Every Corner
Roughly the size of a rice cooker, the DELTA 3 1000 Air weighs just 9.9kg and features a built-in handle—making it easy to move around the house or take wherever you need reliable backup power.
Dimension
220 × 223 × 263 mm
9.9kg
Dimension
220 × 223 × 263 mm
9.9kg
Safe, Quiet Power Your Family Can Use Indoors
<39 dB
Whisper-Quite Operation*
EcoFlow DELTA 3 Air is safe for indoor use with zero emissions—no fumes, no noise, no mess. Enjoy backup power without the smoke, smell, or neighbor complaints. With whisper-quiet operation, it keeps your family powered in a cleaner, healthier environment—indoors or outdoors.
Built to Last for
10 Years
With all-around protection inside and out, the DELTA 3 Air series is engineered for long-term reliability.
UP to 6,439 kWh
DELTA 3 Air series can deliver up to 6,439 kWh,over its lifetime—safe, dependable power for your family, year after year.
Strong Outside
A fire-resistant shell (UL94V-0), shock-absorbing CTC structure, and corrosion protection against oil, salt spray, and humidity keep DELTA 3 Air durable for longer, safer use in any environment.
Safe Inside
Smart BMS technology delivers 24/7 monitoring with seven layers of protection, while long-lasting LFP (LiFePO₄) cells operate safely from –20°C to 60°C—ensuring reliable power and extended battery life.
Strong Outside
Safe Inside
Say Goodbye to Brownout Anxiety
With built-in voltage stabilization, DELTA 3 Air keeps your appliances running smoothly, even when the grid fluctuates— so you can worry less about flickering lights or damaged devices. When instability is detected, DELTA 3 Air automatically switches to its own supply, ensuring uninterrupted and safe power for your home.
LOW
Grid under-voltage.
NORMAL
Voltage is stable.
HIGH
Grid over-voltage.
* A front light indicator shows the status of your grid.
Instant Protection, Real-Time Control
Uninterrupted Power Supply (UPS)
With a switchover speed as fast as 10ms, DELTA 3 Air instantly takes over when the grid goes down. Your lights stay on, your work continues, and your family’s essentials remain powered—without a single interruption.
Smart App Control
Track real-time energy use and battery status directly from your phone. See exactly how much power your essentials consume, get instant alerts when issues occur, and customize charging speeds, schedules, and alerts—all with a tap.
Smart App Control
EcoFlow is the No. 1 portable power station brand in the world based on sales and revenue in 2024. Data source: Frost & Sullivan "2024 Global Portable Energy Storage Market Report."
Research completed in April 2025. Portable power stations are small energy storage devices with built-in lithium-ion batteries with a capacity of 100Wh-3000Wh.
Runtime is based on powering a single appliance. All test results shown are based on internal testing and may vary depending on usage conditions.
Noise levels are measured at a distance of 1 meter under standard lab conditions. DELTA 3 1000 Air operates below 39 dB; DELTA 3 2000 Air operates below 44 dB.
All lifespan-related data is based on EcoFlow’s internal laboratory tests. Results may vary depending on actual usage conditions such as temperature, humidity, and equipment settings. These figures are for reference only and do not guarantee the same outcome in all scenarios.
Tested under controlled laboratory conditions: DELTA 3 2000 Air delivers up to 6,439.68 kWh accumulated over 10 years, while DELTA 3 1000 Air delivers up to 3,219.84 kWh.
UPS performance varies by model: DELTA 3 1000 Air = 20ms, DELTA 3 1000 Air (10ms UPS) = 10ms, DELTA 3 2000 Air = 10ms.
EcoFlow: A Game-Changer for My Work-from-Home Life
true game-changer for my work! My EcoFlow DELTA 2 Series is incredibly easy to use and operate, and I can conveniently power multiple devices. As an online ESL teacher, it has been a huge help during frequent power interruptions, allowing me to continue teaching without disruption. Reliable, convenient, and practical. Definitely worth the investment. Highly recommended! ⚡
A
Anonymous
The device is working great. Tbe customer aftersales service is superb.
The device is working great. The customer aftersales service is superb. I'm planning to buy another in the future.
A
Allen Cerezo
The EcoFlow DELTA 3 Air has been reliable so far
The EcoFlow DELTA 3 Air has been reliable so far, and I really like how fast it charges and how easy it is to use during power outages. The only downside is that its battery capacity isn't enough to run larger appliances for extended periods, so you have to manage your power usage. Overall, it's a solid portable power station that's great for everyday backup power, camping, and charging essential devices.
e
erikporex
Great aside from backup power
Great aside from backup power. I use this during camping with family
T
Therese Santiano
It's easy to use - just plug and play
It's easy to use - just plug and play. It is better to do some research to be able to maximize it in terms of percentage of battery life etc.
Select your country or region
Choosing a selection results in a full page refresh.
Press the space key then arrow keys to make a selection.
Shopping Cart
My Shopping Cart
Delivery of VAT exemption according to § 12 (3) UStG
Dear Customer,
it is possible that a 0% tax rate pursuant to Sec 12 para 3 German VAT Act or Sec 28 para 62 Austrian VAT Act is applicable for the selected products. Please check whether the conditions are met for your case. The seller does not provide tax advice and does not guarantee the occurrence of tax law facts. Click this following links to read more on the requirements of Sec 12 para 3 German VAT Act and Sec 28 para 62 Austrian VAT.
For product(s) sold to Germany, please check if the conditions of exemption from VAT according to Sec 12 para 3 German VAT Act are fulfilled. If this is the case, please tick that you are exempt from VAT on the purchase of the product. By ticking this box, you ensure that
the delivery and billing address are in Germany,
the purchased product will be installed on or near private residences, apartments, and public and other buildings used for activities serving the public good, or on caravans or residential vessels that are not moved or are moved only occasionally, and
the installed gross capacity of the photovoltaic system does not exceed or will not exceed 30 kilowatts (peak), according to the Marktstammdatenregister.
For product(s) sold to Austria, please check if the conditions of applying a tax rate of 0% pursuant to Sec 28 para 62 Austrian VAT Act are fulfilled. If this is the case, please tick that the 0% tax rate applied on the purchase of the product. By ticking this box, you ensure that
the delivery and billing address are in Austria,
the purchased product will be installed on or near buildings used for residential purposes, by public corporations or by private corporations, associations of persons and property funds that serve charitable, benevolent or ecclesiastical purposes, and
the installed gross capacity of the photovoltaic system does not exceed or will not exceed 35 kilowatts (peak).
This 0%-VAT sale is not associated with a binding price quotation by the seller. The total price results from product prices and taxes as well as, if applicable, additional costs such as shipping, etc. If the customer states that he/she is eligible for the 0% VAT rate, the stated price is presented on this basis.
Get a must-have accessory cable for only €1 with your order over €200
₱1.00
EcoFlow BKW-AC Cable
₱1.00
₱1.00₱25
EcoFlow Solar Parallel Connection Cable
₱1.00₱25
₱1.00₱2,099
₱1.00₱2,099
₱1.00
EcoFlow Solar Angle Guide
₱1.00
Get ₱ 500 OFF
