Tired of Frequent Power Outages Disrupting Your Life?
Frequent power outages can be a nightmare, disrupting your routine by plunging you into darkness. Cooking, working, and even relaxing become extremely inconvenient. They strike at the worst times, leaving you feeling frustrated and helpless.
LiFePO4 Battery,Built to Provide Long-lasting Support
3 ways to charge, from 0 to 100% in just 2 hr
Easily handle long-lasting, high frequency power outage
EcoFlow E980 Portable Power Station can be charged using an AC cutlet, solar panel, or DC charger. With a full AC charge achievable in just 2 hours, it enstures quick top-ups before the next power outage without damaging the battery.
13 Output Ports for Multiple Appliances
Charge all your home's appliances simultaneously
EcoFlow E980 Portable Power Station features 13 output ports, providing reliable
charging for a wide range of household devices to meet thepower needs of your entire family.
Lightweight and Portable
Power anytime, anywhere you need it
With 2 built-in handles and a compact design, easily move EcoFlow E980 Portable Power Station from room to room to handle urgent household needs. It's also portable enough to take outside for recreation activities or to support work, making it a highly versatile and flexible energy solution.
Simple, Smart, and Easy to Use
Easy enough for all to use
The EcoFlow E980 Portable Power Station is plug-and-play—no electrical knowledge or installation required. It works just like a standard home power outlet. A screen displays real-time power usage, so you can monitor and adjust as needed. For a more personalized experience, why not use the EcoFlow app to get more smart control.
What are the advantages of the E980 compared to a fuel generator?
The E980 is eco-friendly with zero emissions, operates quietly, has no maintenance costs, provides instant power without waiting for startup, and saves money on fuel expenses. It can be used in the house without noise and exhaust fumes.
What are the advantages of the E980 compared to lead-acid batteries?
Compared to lead-acid batteries, the E980 stands out with lighter LFP battery packs, longer lifespan and lower cost. While lead-acid batteries typically Iast only 300-500cycles, the E980 delivers 3000+ cycles - that's a 6-10 times longer lifespan. E980 can charge faster than lead-acid batteries and has advanced safety features to prevent overcharging and short circuits.
How can I maintain the battery to extend its lifespan?
The E980 features a Battery Management System (BMS) that inherently extends its lifespan compared to similar products. To further maximize the batttery's longevity, it is important to regularly charge it to prevent deep discharge, avoid exposing it to extreme temperatures. Users can protect the battery by flexibility setting lower charging speed, the charge limit to 80% and the discharge limit to 20% via the app. Additionally, periodically inspect the battery for any damage and ensure all connections are secure.
Is the E980 suitable for outdoor activities?
The E980 is designed to be perfect for outdoor activities. Its lightweight and portable design make it easy to carry, while its support for car charging adds to its convenience. The E980 is also built to be durable and withstand rugged conditions, making it a versatile and cost-effective solution for indoor or outdoor scenarios.
