EcoFlow 400W Portable Solar Panel | EcoFlow PH
₱29,990.00
30 Days Price Match
Up to 5 Years Warranty
Fast & Free Local Shipping
Lifetime Customer Support
Regular price ₱29,990.00
Sale price ₱29,990.00 Regular price ₱52,790.00
Save ₱22,800
EFNEWS
Copy
High-Capacity Backup: Supports home backup, off-grid cabins, and high-demand outdoor appliances with ease.
Single Panel, Big Power: One 400W panel provides enough energy for short-term charging needs.Outdoor-Ready Design: Operates across a wide temperature range, built to handle diverse outdoor conditions.
IP68 Waterproof & Weatherproof: Durable enough for permanent outdoor placement—no daily setup required.
Compact & Foldable: Despite its power, the panel folds for easy storage and transport.
También te puede interesar
₱29,990.00 ₱52,790.00 -₱22,800.00
30 Days Price Match
Convert sunlight into clean, renewable energy using 400W portable solar panels, perfect for camping, RVs, and home use.
400W Portable Solar Panels
Our 400W portable solar panel offers high solar output, conversion efficiency rating, and a convenient folding design so it’s ready to grab and go at any time.
High Solar Output and a One-piece Folding Design
Charge faster, wherever you go.
With a unique folding design, our 400W solar panel combines powerful energy production with portability. To achieve a higher solar conversion efficiency of 23%, we use multi busbar monocrystalline cells, so you get even more energy to recharge your portable power station.
An Integrated, Self-supporting Stand
Optimize your energy.
EcoFlow's 400W solar panel comes complete with a protective case that doubles as a sturdy supporting stand. Simply set up your panel anywhere and conveniently adjust its angle to get the most sun possible.
Ready for the outdoors.
Made from durable and flexible materials, the portable solar panel is perfect for off-grid living and travel. Its multi-layered design offers high impact resistance for the rugged outdoors, while its 16 kg light-weight means effortless carrying to a campsite. A rigid layer embedded in the carry case protects the panel from overbending when you carry or store it.
Built to weather the storm.
Our 400W solar panel can carry on collecting energy even during a downpour. With a protective ETFE film and a high IP resistance level of 68, the solar cells can withstand environments from humid and wet to dry and dusty.
Take solar power on the go.
EcoFlow’s 400W solar panel is a camping or RV must-have. The compact design saves valuable space for your other travel essentials. When you’re ready to head off on your next adventure, simply collapse the panel down to store in your van or car.
Solar to XT60i Charging Cable
400W Portable Solar Panel Bag
Snap hook*4
Snap hook*4
User Manual & Warranty Card
Are portable solar panels effective?
Portable solar panels are an extremely effective, clean, and renewable way to charge a portable power station. EcoFlow 400W portable solar panels have a larger wattage than typical solar panels and are more efficient due to their monocrystalline cells. String up to three 400W portable solar panels and use with a DELTA Pro portable power station for an input of 1200W. Additionally, EcoFlow portable power stations use an MPPT algorithm to ensure a constant energy supply. Unlike static solar panels, portable solar panels are easily moved and adjusted depending on where the sun is in the sky.
Where do you place portable solar panels?
Positioning portable solar panels at an angle between 30-45 degrees, facing the sun's direction, is best. EcoFlow portable solar panels have a built-in stand that can be adjusted depending on the time of day.
Which solar panels are best for camping?
Solar panels that are portable, foldable, and lightweight are the best kind for camping. Pair with a portable power station for immediate power that is clean, green, and renewable.
Rated Power
400 W
Cell Type
Monocrystalline silicon
Efficiency
22.60%
12 months
41.7*93.1*0.98 in (105.8*236.5*2.5cm)
Open Circuit Voltage
48V (Vmp 41V)
Short Circuit Current
11A (Imp 9.8A)
Weight (Solar Panel)
Approx. 16 kg
Weight (with Kickstand Case)
Approx. 19 kg
