EcoFlow 110W Portable Solar Panel | EcoFlow PH
₱10,990.00
30 Days Price Match
Up to 5 Years Warranty
Fast & Free Local Shipping
Lifetime Customer Support
Regular price ₱10,990.00
Sale price ₱10,990.00 Regular price ₱14,990.00
Save ₱4,000
EFNEWS
Copy
• Weighs only 5.1lbs, making it extremely lightweight
• 258° flexibility, making it easy to fit to any surface
• An IP68 waterproof rating for added durability
• Universally compatible
También te puede interesar
₱10,990.00 ₱14,990.00 -₱4,000.00
30 Days Price Match
Get off the grid with EcoFlow’s 110W Solar Panel for renewable energy wherever you end up.
Powerfully portable
With an industry-leading 23% conversion rate, it’s far lighter and approx. 10% smaller than similar portable solar panels on the market. That means a faster, easier charge wherever you are.
Self-supportable
Take it camping, on a road trip or in your backyard with a case that doubles as a stand. Unzip and prop up your panel at just the right angle to ensure maximum solar coverage.
Waterproof & Durable
Designed to withstand your adventurous lifestyle, this panel is IP68 certified. That means we dunked it underwater for 72hrs in lab conditions. Just to make sure*. Built with a high-strength composite, it can take a beating too. That’s an all-weather ready panel designed to stand the test of time.
* Water and dust resistance were tested under controlled laboratory conditions with a rating of IP68 under IEC standard 60529 (maximum water depth of 1 meter for up to 72 hours.)
It comes with a carry case too.
On the go? Keep your panel folded up and protected while you hit the road. Save valuable trunk space and go easy knowing your panel is safe. Once you arrive, simply unfold, prop up and start generating clean, green electricity.
Solar to XT60i Charging Cable
110W Portable Solar Panel Bag
Snap hook*4
Snap hook*4
User Manual & Warranty Card
Unfolded Dimensions
178.5 × 42.0 × 2.5 cm
Folded Dimensions
42.0 × 48.0 × 2.5 cm
Weight
4 kg
24 months
Rated Power
110W (±5W)
Efficiency
22% – 23%
Open Circuit Voltage
21.8V (Vmp 18.4V)
Short Circuit Current
6.5A (Imp 6.0A)
Cell Type
Monocrystalline Silicon
Operating & Storage Temperature
−20°C to 85°C
