Power. Never Been This Easy
Charge 0-100% in 70 mins
Fastest charging speeds ever.
RIVER 2 Pro beats the industry charging speed standard, fully charging in only 70 minutes.. That's 5x faster than other portable power stations on the market and 27% quicker than previous generations. Fully charge RIVER 2 Pro while you pack your bags, so you'll always be ready for a last-minute trip.
LiFePO4 Battery Chemistry
4 Ways to Charge
Charge anywhere
AC Charging
Car Charging
USB-C Charging
The most easy-to-use independent solar power system. Take it to camping or RV trips with it. Have stable, durable, and reliable energy on hand whenever you need. Join hands with us in this energy-sharing world and live green.
RIVER 2 Pro Solar Generator produces up to 1.8kWh daily, which means sufficient power to run your essential appliances smoothly for almost half a day. You'll always be ready. Using RIVER 2 Pro Solar Generator every day decreases your whole-year carbon emissions by about 143kg. That's like planting 8 trees in a year!*
X-Boost Up to 1600W
Small size. Big power.
Lightweight at only 7.8 kg
Monitor, control, and customize your power usage intelligently with the EcoFlow app.Monitor
Control
Customize
Customize
Constant Updates
Power. Anywhere. Anytime.
Product Details
1.RIVER 2 Pro 2.AC Charging Cable 3.Quick Start Guide
BATTERY INFO
Capacity: 768Wh
Cell Chemistry: LFP
PORTS
Solar Input: 11-50V, 13A, 220W Max
RECHARGE TIME
Car charging: 9 hours
USB-C charging: 9 hours
Solar charging (1x 220W portable solar panel): 3.5 hours
GENERAL
Net Weight: Approximately 7.8kg
Dimensions: 270 x 260 x 226mm
App Control: Wi-Fi, Bluetooth
