EcoFlow 12V 100Ah Lithium Trolling Motor Battery
₱10,990.00
30 Days Price Match
30 Days Price Match
Up to 5 Years Warranty
Fast & Free Local Shipping
Lifetime Customer Support
Regular price ₱10,990.00
Sale price ₱10,990.00 Regular price ₱16,990.00
Save -₱6,000
coupon image
EFNEWS
Copy
  • Best lithium battery for 13.6-31.8 kg trolling motors
  • 300A@30s instantaneous output current, for smoother and more precise control of the trolling motor.
  • 1280Wh capacity, 1280W continuous output
  • Best-in-class EV-grade LFP cells with 6000+ cycles
  • 5-year warranty, UL1973, FCC, UN38.3, RoHS certified
  • 50% less weight,  50% more energy than lead acid
  • IP65 waterproof rating
  • X-Guard BMS with low-temp cut-off
  • Highest-level UL5VA flame-retardant casing
Bundle Options
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
₱10,990.00 ₱16,990.00 -₱6,000.00
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
30 Days Price Match
30 Days Price Match
Reel in Power
100Ah (1280Wh) & Expandable
100Ah (1280Wh) & ExpandableOur 12V battery is designed to start your boat's trolling motor with a continuous output of 1800W and a peak output current of 300A.Add up to 16× batteries to power your RV, off-grid cabin or trolling motor for even longer.
12V Trolling Motor
RV
Off-Grid Cabin
Workshop
No replacements for 10 years
Long-lasting with 6000+ Cycles
With automative-grade LFP cells, your battery will last more than 10 years before it loses capacity.Our lithium 12V battery lasts 10 times longer than lead-acid, so you save money in the long run. A 24/7 health monitoring algorithm extends battery life even further.
Make long-term savings
A Cost-Effective Solution
Our battery offers a low lifetime cost of just $0.03 per kWh, that's $265 for 1.28kWh over 6000 cycles. It boasts the lowest lifetime cost among LFP 12V batteries in the industry, ensuring you save money while enjoying reliable, hassle-free power.
Robust and secure
Experience Superior Battery Protection
X-Guard technology provides fail-safe protection and unmatched durability, ensuring optimal performance even in harsh conditions.
Durable and protective
UL1973-Certified with CTC Design
Our industry-first CTC (cell-to-chassis) process integrates the battery shell and internal components into a single, robust structure. This innovative design offers higher strength, external security, and improved drop resistance compared with traditional lead-acid and other LFP 12V batteries. Whether stored in a basement, taken on a bumpy RV ride, or used at job sites and events, the battery is protected against impact damage and malfunctions, ensuring consistent performance even in the toughest conditions.
Always-safe and reliable
Unmatched Protection
Our X-Guard BMS (Battery Management System) algorithm provides around-the-clock protection. Covering up to six monitoring and safeguard measures, including low temperature, over-discharge, overcharge, high temperature, short circuit, and overcurrent, it ensures a fail-safe recovery. Unlike most lead-acid batteries that lack a BMS, our battery mitigates the risk of damage in harsh environments. Whether facing extreme weather conditions or fault recovery, our dual-channel CMOS protection guarantees automatic overload protection and recovery.
Enhanced safety and reliability
Water-Resistant
& Temperature Safe
Experience enhanced safety with vehicle-grade LFP battery cells. Meeting top UL9540 standards, this 12V battery is designed to minimize heat and resist water, even from low-pressure jets. With a 5VA-grade, self-extinguishing casing, it automatically extinguishes itself within 30 seconds in the unlikely event of a fire, preventing the risk of flames spreading.
Small Size, Big Power
With an 8% smaller volume than lead-acid, the EcoFlow 100Ah 12V battery can fit into small spaces for storage and acts as a slot-in replacement for Group 27-31 batteries. Its built-in handle makes it convenient to carry or move whenever you need to.
Stay powered anywhere
3 Fast Charging Methods
Charge the LFP 12V battery using solar, generator, or from the grid, so no matter where you are, there's an option. Fully charge in as fast as 2 hours, 6 times quicker than lead-acid batteries.
Charge 0-100 in Only 2 Hours
Trusted by 3,000,000+ users
EcoFlow is sold in more than 100 countries and regions, with a user base of 3,000,000+ worldwide. Our products are at the forefront of industry technology and have been certified and affirmed by tech media and awards. We are authorized as official strategic partners by major RV and outdoor industry companies.
Quality Services You Can Expect
5 years warranty
7/24 customer service
UL CE FCC UN38.3 RoHS
Certified
Cell Type
LiFePO4
6000 (0.5C@25°C/77°F, 80% DOD)
Voltage Range
10V-14.6V
Rated Capacity
100Ah
Energy
1280Wh
Max. Continuous Charge Current
100A
Max. Continuous Discharge Current
100A
Peak Discharge Current 30 Seconds
300A
Voltage Range
14.4V±0.2V
Recommend Charge Current
≤50A
Charge Operating Temperature
0°C-55°C (32°F-131°F)
Discharge Operating Temperature
-10°C to 55°C (14°F to 131°F)
Storage Temperature
0°C-45°C (32°F-113°F)
Weight
26.5 lb
Size
11.4x6.9x8.7in
IP Rating
IP65
5 years
Subscribe to receive updates on new products and exclusive promotions.
Get ₱ 500 OFF
