₱128,690.00
Regular price ₱128,690.00
Sale price ₱128,690.00 Regular price ₱139,890.00
Save -₱11,200
Tax excluded.
coupon image
Subscribe & get ₱300 Off coupon
EFNEWS
Copy
Get up to ₱98,604.00 in rebates through the Residential Clean Energy Credit. Learn More >
Up to ₱98,604.00 in rebates
Amount 30% off
Claim By: December 31, 2032
Program: Residential
  • Rentals do not qualify.
  • Must be grid-tied.
  • Compatibility - Works seamlessly with EcoFlow DELTA Pro 3
  • (The EcoFlow DELTA Pro Smart Extra Battery is compatible with the EcoFlow DELTA Pro 3. ).
  • Scalable Power - Expandable up to 12kWh for increased capacity.
  • Long-Lasting Battery - LFP battery with 4000 life cycles to 80% capacity.
  • Easy to Use - Plug-and-play design for straightforward operation.
  • Stackable Design - Perfect for home or indoor power backup applications
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
₱128,690.00 ₱139,890.00 -₱11,200.00
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
payment method
An Intelligent Subpanel For Outage
Protection And Savings In One
The EcoFlow Smart Home Panel 2 is the center of your whole-home backup solution,
working alongside EcoFlow DELTA Pro 3, generators, and solar panels to protect your
thome. With a fast, automatic switchover, you'll have reliablebackup whenever needed. It
allows you to customize your energy usage based on time-off-use rates and your home's
solar energy production.
Plug and Play
The smart extra batteries are easy to connect with the main unit of EcoFlow DELTA Pro 3. Enjoy a seamless, plug-and-play setup. The compact and portable design adds convenience to your power management.
Explore the Secure Feeling EcoFlow Brings to You
Built with state-of-the-art automotive-grade LFP cells for safe and reliable service. Our strong 5-year warranty ensures peace of mind.
Energize Every Moment That Needs Electricity
Power almost all your essential home appliances with the robust 4000W and dual 120V/240V capabilities of a single unit. Add extra batteries to extend the convenience even further.
Off-grid
RV
Jobsite
Cutting-Edge Design, Sleek and Striking
Boosts portability with wider wheels, ergonomic handle, and a compact design. Perfect for dynamic lifestyles and maximizing family space.
Effortless All-in-One Command With the EcoFlow App
Control and monitor your home's power remotely with ease using the EcoFlow app. Track every watt and customize your power usage for optimal efficiency.
4096Wh
Input Port
40V-58.4V=80A Max
Output Port
40V-58.4V=100A Max
Dimension
694mm*295mm*215mm
Weight
33kg
What’s in the box
1. EcoFlow Delta Pro 3 Smart Extra Battery
2. Quick Start Guide
3. Safety Guide
4. Warranty Card
5. EcoFlow Extra Battery Cable
Compatible with
EcoFlow DELTA Pro 3
Display
LED Array
Discharge Temperature
14°F~113°F
Charge Temperature
32°F~113°F
Storage Temperature
14°F~113°F
Subscribe to receive updates on new products and exclusive promotions.
Get ₱ 500 OFF
