EcoFlow DELTA 3 Portable Power Station | EcoFlow PH | EcoFlow PH
₱53,990.00
Regular price ₱53,990.00
Sale price ₱53,990.00 Regular price ₱60,790.00
Save ₱6,800
Subscribe & get ₱300 Off coupon
EFNEWS
Copy
* 5 fast recharging methods (AC, Solar, 800W Alternator Charger, Smart Generator 3000 (Dual Fuel), Multicharging)
*5-year warranty
₱53,990.00 ₱60,790.00 -₱6,800.00
DELTA 3
4 Ways of Industry-Leading Fast Charging
Perfect for Indoors, Outdoors, or On-the-Go
AC Charging
Car Charging
Multi-Charging
With EcoFlow's X-Stream technology and a 1500W AC input, the DELTA 3 charges from 0-100% in just 56 minutes. A quick 30-minute charge provides hours of emergency backup before a power outage.
500W MPPT Solar Input, Full Charge in 130 Minutes²
The DELTA 3 fully charges in 130 minutes with a 500W MPPT solar input, even in limited sunlight. Recharge conveniently during outdoor breaks like lunchtime.
800W Car Charge, Full Charge in 1.3 Hours³
Using an 800W car power source, the DELTA 3 fully charges in just 1.3 hours—8× faster than traditional options. Charge on the go, no pre-charging required.
AC + Solar, Full Charge in 56 Minutes⁵
With 1500W max input, combining AC and solar, the DELTA 3 charges fully in 56 minutes. Solar is prioritized to save money during daily use.
1800W Output, 3600W Surge – Power Beyond Limits
The EcoFlow DELTA 3 supports 99% of household devices, including refrigerators, TVs, and computers. With X-Boost, it powers appliances over 2600W, like ovens (2150W), hair dryers (1800-2500W), and kettles (1200-3000W). Ideal for home backup, RV, and outdoor use, this powerhouse ensures you're always prepared.
Home backup
Outdoors
RV
Professional work
Ensure Reliable Backup with a 10 ms UPS⁶
30 dB Ultra-quiet Operation.
Barely perceptible under 600W, blending seamlessly with natural ambient noise (30 dB). Whether inside a tent or indoors, it won’t disrupt your sleep.
Peace of Mind for Backup Power, Convenient for Daily Use
Powered by the EcoFlow Oasis intelligent energy management system:
Flexible Expansion for Ultra-Long Runtime
Expand conveniently up to 5kWh* for extended use.
*Compatible with the Extra Batteries of DELTA 3, DELTA 2 Max, and DELTA 2.
Smaller Size, Same Power
Long-Lasting and Durable—Reliable Backup
Triple protection for guaranteed safety:
LFP Battery
IP65 Battery Pack
BMS
Third-gen LiFePO4 (LFP) cells enable fast charging with 4000 cycles to 80% capacity[8], ensuring up to 10 years of use—25% above the industry standard.
IP65-rated for water and dust resistance, ensuring durability in diverse environments and protection against harsh conditions.
Over 40 safety measures protect against current, voltage, temperature, and circuit risks. Advanced thermal runaway protection prevents explosions and fires for maximum safety.
Compact and Portable Design
Effortlessly fits in any space and is convenient to transport.
11 Outputs
Compact and Lightweight
398*200*284mm
22.549 L
≤12.5kg
1024Wh
Extra Battery
Support DELTA 2 EB, DELTA 2 Max EB, DELTA Pro 3 EB, and DELTA 3 EB (Up to 5kWh)
Total Output Ports
11
1800W (surge3600w)*4
2400W
USB-A Output (Fast Charge)
2×18W Max
2 ports, 100W Max
Car Power Output
12.6V, 10A, 126W MAX
DC5521 Output
2X 12.6V,3A MAX
AC Charging
1500W (56 min)
DC charge input*1 11V-60V
500W Max*1 (130 Min)
1500W(56 min)
Car Charging
800W, in 1.3 Hour
LFP (LiFePO4 battery)
4000 cycles to 80+% capacity
Connectivity
IP65
UPS
<10ms
Noise
600W<30db;1200W<40db
5 years
Footnotes
[1-8] All the test results displayed on the page are based on our internal testing, subject to different conditions, including temperature variations, humidity levels, and equipment calibration standards. Please note that these results are provided for informational purposes only and should not be considered conclusive evidence for all scenarios.
*SGS data source: Analysis based on EcoFlow's internal test data of 1kWh mainstream power stations on the market and their official data. Data is current as of August 28, 2024.
*Download the EcoFlow PowerManager App to activate the NAS support function on your computer, then install the NUT Server software on your NAS system, connect your DELTA 3, and activate HID support. The formal launch version will come later in December.
*EcoFlow DELTA 3 are compatible with Extra Battery of DELTA 3, DELTA 2 Max, DELTA 2.
