EcoFlow DELTA 2 Max | Max Power Anywhere | Portable Power Station | EcoFlow PH
₱83,990.00
Regular price ₱83,990.00
Sale price ₱83,990.00 Regular price ₱97,790.00
Save -₱13,800
Expandable capacity: 2-6kWh expandable capacity to fit your energy storage needs. Add up to two DELTA 2 Max Smart Extra Batteries to hit 6144Wh. Ideal for home backup, caravanning, outdoors or even everyday use.
Built to last 6× longer: Get 10 years of daily use until hitting 80% of its original capacity. That's down to its LFP battery chemistry giving you 3000 cycles.
Level up with the EcoFlow PowerStream Balcony Solar System: Pair with an EcoFlow PowerStream Microinverter and gain a grid-tied solar energy solution that powers your home day and night.
Huge AC output: With X-Boost mode, get up to 3100W output power to run 99% of home appliances. Power 13 devices at once, including 4 AC outlets.
Fastest recharging: World's fastest AC recharging and X-Stream dual AC+Solar charging speeds. Up to 1000W solar input to charge in as fast as 2.3 hours
Capture more energy: 99% MPPT efficiency maximises solar generation during the daytime.
Customised in-app energy management: Prioritise solar or AC charging, view input and output power, battery levels and more.
5-year warranty
₱83,990.00 ₱97,790.00 -₱13,800.00
Power Every Day For 10 Years
EcoFlow DELTA 2 Max
10-Year LFP Battery,
Built To Last 6× Longer.
Durable, Safe, Lightweight
With its upgraded LFP battery chemistry, DELTA 2 Max has a lifespan of 3000 complete cycles until it reduces to 80% capacity. You'll get pretty much 10 years of power, even if you use it every day.
LFP Battery Chemistry
That's 6x Longer Than Other Power Stations With A Similar Capacity And Output.
Advanced BMS Protection
Protective Layers Inside And Out
Robust Design
Upgraded Tech, Lighter
Weight
Even with its upgraded LFP battery, DELTA 2 Max is still 30% lighter than similar 2kWh LFP power stations on the market.
DELTA 2 Max powers almost all the devices you need with a large 2400W AC output. Plus, with X-Boost proprietary technology, run appliances with an output of up to 3100W. Compared with other power stations, DELTA 2 Max can power more devices, while still preventing overloading and overheating.
Power of the entire family
2048Wh Capacity
A generous 2048Wh capacity makes DELTA 2 Max ideal for home backup, running your essentials for hours. With its lightweight design, DELTA 2 Max is portable enough to grab and go on the next camping trip.
*Data based on a 120W referigerator.
Power for the entire family
2048Wh Capacity
2048Wh Capacity
2048Wh Capacity
Home Backup
RVing & Outdoors
DIY Projects
Filmmaking & Photography
Expandable up to 6kWh
Triple the power.
Fuel Up 80% in Only 43 Mins*
With DELTA 2 Max's upgraded tech, combine up to 1000W solar input with AC for world-leading charging speeds. In only 43 min get an 80% charge. Or stick with AC for an 80% charge in a speedy 53 mins.
Up to 1000W Solar Input
Solar Charging Times
880W Charge approx. 2.6 hours
800W Charge approx. 2.8 hours
Take Control Of Your Power.
Take control of your power.
Smart Automatic Control
AC Always-on
Energy Management
Low Battery Reminder
Experience peace of mind during power cuts
With our all-new AC Always On Mode, the AC power button stays on, even during a power cut or after the grid power is back, keeping your appliances powered no matter what.
Easily adjust power
Easily adjust AC or Solar input to fit your needs: backup power reserve or energy savings. Prioritise solar energy input via the EcoFlow app when using X-Stream AC + solar dual charging.
Always power ready
Extensive 5-Year
As Quiet as 30 dB
Peaceful charging.
*From a distance of approximately 20 in., noise level is 30 dB (with low input and 500W output) vs. other power stations with 55 dB or higher.
DELTA 2 Series
Expendable LFP Battery Power Solution
Learn More about DELTA 2
DELTA 2 Max
DELTA 2 Max
AC Charging cable
AC Charging cable
Car charging cable
Car charging cable
DC5521 to DC5525 Cable
User manual & warranty card
2048 Wh
Extra Battery
X-Boost 3100W
USB-A Fast Charge
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
AC Charging
X-stream Fast Charge 2300W, 10A
AC Input Voltage
Car Charging
Support 12V/24V battery, 8A
LFP (LiFePO4 battery)
3000 cycles to 80+% capacity
Connectivity
Wi-Fi & Bluetooth
Net weight (lbs)
50 lbs
Net weight (kg)
23 kg
